Order Ford 4500 Parts Online
4500 TLB Trans/Rear End
BobC
02-14-2008 18:47:17
Do the transmission and rear end on the 4500 use the same oil resovoir? Manual shift, no shuttle clutch. I changed oil in the transmission today but am not sure if that also applies to the rear end (approx 3 gallons to fill). I found two fill level plugs on the right side near the foot plate. One definitely applies to the transmission. Not sure about the other, located about 6-8 inches behind the transmission plug. I see no oil flow from it.
Thanks.
steve n carol
02-15-2008 08:47:41
 Re: 4500 TLB Trans/Rear End in reply to Bendee, 02-14-2008 18:47:17
This intrests me, For me to check the fluid in the diff on my 4500...I have to remove a square head check plug on the trans housing (at the foot rest on the draft / positioner side), because there isn't a dipstick..... I'm glad they use the same fluid.....sl
Murn Ga
02-14-2008 19:06:52
 Re: 4500 TLB Trans/Rear End in reply to BobC, 02-14-2008 18:47:17
No. The same fluid but different res. The diff,hyd will be about 8 gal I think.
BobC
02-14-2008 19:16:56
 Re: 4500 TLB Trans/Rear End in reply to Murn Ga, 02-14-2008 19:06:52
Thanks, and my apologies for spelling reservoir incorrectly.
soundguy
02-15-2008 05:54:23
 Re: 4500 TLB Trans/Rear End in reply to BobC, 02-14-2008 19:16:56
Most here don't nitpick on spelling.. or some of us'd be rund off by now. ;)
soundguy
