Order Ford 4000 Parts Online
ford 4000 su
acdave
02-18-2008 10:11:24
did the 4000 su tractors have the bigger engine in them does anyone know what year they started the su i am looking at one in ky and was wondering if it had the bigger hp thanks Dave
streaker
02-18-2008 14:55:40
 Re: ford 4000 su in reply to acdave, 02-18-2008 10:11:24
Just out of curiousity, I am wondering how does a 1965 4400 ford compare to the SU? It has a 3 cyl. diesel, loader, heavy front axle.
Thanks
acdave
02-18-2008 13:45:17
i was wanting to pull a 6 row planter without fertlizer and a sprayer and hay equipment with the tractor
RodInNS
02-18-2008 13:27:27
I'm not sure what year they started production of the 'SU', but I'd think it was probably 65 or 66. 'SU' refers to 'Special Utility' or it's often called 'Super Utility' around here. At any rate, the 4000 SU was nothing more than a standard 4000 AP which was fitted with the 3000's front axle. Basically you got a 4000 in a 3000 size package. There were no other differences that I'm aware of.
Rod
Mathias NY
02-19-2008 04:25:09
 Re: ford 4000 su in reply to RodInNS, 02-18-2008 13:27:27
If a 4000SU has a 3000 front axle, could a 4000 axle be installed on a 3000? I believe the answer will be 'not worth the effort,' but I'm curious if it is possible.
RodInNS
02-19-2008 05:23:54
 Re: ford 4000 su in reply to Mathias NY, 02-19-2008 04:25:09
I've never done that but I don't see why it couldn't be done. The better question is why would you bother? There again you would need to change out the axle, bolster, cowl and the ALL of the steering gear. It is a heavier axle, but not sufficiently heavier to make a change worthwhile in my opinion. If you need a heavy axle you would go with one of the industrial variants that was made for the 3000 and that would minimize the other things you would need to change. An axle from a 3400 or 3500 would be the ticket there.
Rod
soundguy
02-18-2008 12:36:12
Ditto what OFM said.. 4ksu had the 'weak' front axle..
soundguy
Old Ford Mechanic
02-18-2008 10:34:42
Dave the SU had the same 52 Hp that the other 4000's did.The SU has a 3000 front axle.Heavier axle on plain 4000 is better if you are wanting a loader tractor.
Richard_Weaver
02-18-2008 12:31:58
 Re: ford 4000 su in reply to Old Ford Mechanic, 02-18-2008 10:34:42
Doesn"t the SU have the heaver rear axle housing?
RickB
02-18-2008 14:13:40
 No. in reply to Richard_Weaver, 02-18-2008 12:31:58
"Doesn"t the SU have the heaver rear axle housing?"
The same rear axle as the all purpose 4000. The 4000SU has a 3000 front bolster, shell, and front axle, as well as smaller rear rubber. It's not a 3000 with a bigger motor, it's a 4000 with a different front axle. Independent PTO and wet brakes just like a 4000AP.
