proofmeter repair photos
NWMO 901 SOS
02-19-2008 21:30:25
Good evening friends,
I posted a few pics of my proofmeter repair Monday and Johnbud indicated he was interested in seeing them all. This is my first attempt at sharing a photo album (23 photos in all).
I don't know the proper names of the different pieces, so I call them what I think they should be called. Hope it isn't too confusing.
I didn't start photos until I had the proofmeter apart. The "primary shaft" is retained in the proofmeter by sliding through the "housing" and then a brass keeper is slid on the the end of the shaft and the shaft flared. I demoed the brass keeper with a drill and the flared end of the primary shaft with a pair of pliers. It would be best to grind the flared end. I had to drive the shaft through the body which damaged the "carrier" where the shaft rides some. I think it cleaned up pretty well, but if I had it to do over, I would grind the flare off. Make sure you don't grind more than necessary though, as you need to have the end of the shaft protruding to epoxy a fabricated keeper when putting back together. There were some small rivets etc. that had to be carefully drilled as well. I epoxied all the spots previously held with rivets, "buttons", etc.
Finally, the link should take you to the album. If you click on a photo it will provide the photo in full size and I have also provided a small description/comment that should be at the bottom of each photo.
Link
I put this together with a standard dial up connection, but it may be pretty slow for some, don't know. :roll:
Chris
richardp3
02-20-2008 18:53:33
 Re: proofmeter repair photos in reply to NWMO 901 SOS, 02-19-2008 21:30:25
Nice job. I tried to rebuild my proofmeter, but the needle spring was wrapped around the axle. Totally destroyed due to the internal clutch locking up from moisture/corrosion.
Anyone have any broken proofmeters for sale cheap?
Royce TN
02-20-2008 14:54:14
Thanks for the great photos. I didn"t know you could repair those!
NWMO 901 SOS
02-20-2008 10:25:11
 Re: proofmeter repair photos in reply to Jr in nwmo, 02-19-2008 21:30:25
Brian Allen said: (quoted from post at 10:25:00 02/20/08) Great job!
I hope it holds up for you.
How many hours did it take to complete overall?
Congratulations.
Thanks,
I didn't keep perfect track, but probably had 6-8 hours total in project. I probably had about the same in uploading photos and organizing. I wish some of the photos had been a little clearer. Glad you enjoyed it. :D
Chris
Brian Allen
02-20-2008 07:25:00
Great job!
Congratulations.
Michaels Dad
02-20-2008 04:06:25
 Re: proofmeter repair photos in reply to FarmerDan, 02-19-2008 21:30:25
Great job.
8) 8) 8) 8)
