Order Ford 3000 Parts Online
Ford 3000 questions
Andrew O. (TX)
12-28-2001 07:34:25
I am looking at a used Ford 3000 tractor. I think it is a mid to late 60's model. Does anyone know of any problem areas I should look for? How many hp does it put out? Oh and how much does it weigh? Thank you for your responses!
hv-ga
12-28-2001 07:52:22
 Re: Ford 3000 questions in reply to Andrew O. (TX), 12-28-2001 07:34:25
Andrew, check out oaktree.com for specs on weight etc. If the tractor has power steering make sure it works or adjust the price. It's a potential big ticket to repair (and fairly difficult). Good luck.
steve
12-28-2001 09:19:31
 Re: Re: Ford 3000 questions in reply to hv-ga, 12-28-2001 07:52:22
does it have a two stage clutch? how many speeds? watch hydraulics see if they "bump" when lifting, what kind of injector pump does it have? the old simms type is a little hard to find and time, the newer cvc pumps are easier to work on, I have some parts and pieces in my shed,, STeve
