Order Ford 4000 Parts Online
Ford 4000 transmission oil
Charlie C.
02-22-2008 12:46:13
Could you fellows tell me what wt. oil is used in a 73 4000 8/2 transmission?
I have the part # that ford gives but I would like to be able to buy the oil at costco or some other place.
Thanks for your help.
Charlie
Charlie C.
02-25-2008 16:23:13
 Re: Ford 4000 transmission oil in reply to Fordfarmer, 02-22-2008 12:46:13
Thanks for all of the replys guys.Guess that is another oil that I will need a supply of, a couple of qts. at least.
Texasmark
02-25-2008 07:18:49
 Re: Ford 4000 transmission oil in reply to Charlie C., 02-22-2008 12:46:13
I think part of the reengineering of these tractors for the '65 model year (which included the cylinder reduction from 4 to 3) included combining the hyd and diff systems into one sump. With that came 134 combination hydraulic/transmission fluid which they used in the separate tranny sump also.
Prior to that it was heavy-thin-heavy (tranny-hyd-diff)in the 3 sumps.
Mark
Charlie C.
02-23-2008 11:07:57
On my tractor the rear end plug is in a little different position than what the owners manual showes. The plug that is on my tractor is a square head plug located in fornt of the rear brace for the right hand running board. The book shows the plug located more to the rear..
streaker
02-23-2008 10:16:26
How do you know how full to fill it? My 1965 4400 has no dipstick, just a plug to unscrew. Both for the tranny, & the rear end. Do you fill them up till you see fluid? or is there some other way? I have no manual for this tractor. Thanks in advance.
RickB
02-23-2008 10:19:38
 Re: Ford 4000 transmission oil in reply to streaker, 02-23-2008 10:16:26
Fill each housing till it runs out the check plug on the side.
souNdguy
02-22-2008 20:38:30
I've been using the walmart UTF oil in my larger tractors for a while now.. and before that used TSC's utf with no problem.
soundguy
RodInNS
02-22-2008 14:07:16
Ford/NH 134D is the correct oil. Any other oil meeting that spec will suffice. Walmart's TDH is but one example. You can also use 80W90 gear oil but it will tend to shift harder, especially in cold weather. I'd use 134D.
Rod
