Order Ford 3000 Parts Online
Ford 3000 --needing help with a weird lever
Andrew O. (TX)
12-28-2001 09:55:22
My dad just looked at a Ford 3000 for sale. It is a 8 spd transmission. It has a ford trip loader on the front of it. The problem is that when my dad drove it, he said in order for the rear lift to work, there was a spring loaded lever under the right-hand side of the seat that had to be held down. Is this a problem? or a easy fix? The tractor runs well (diesel). What is the purpose of the lever? If it is not a huge problem, we want to purchase it. Please fill me in... Thank you!
Scott
12-28-2001 10:03:57
 Re: Ford 3000 --needing help with a weird lever in reply to Andrew O. (TX), 12-28-2001 09:55:22
The lever is in draft control now (for plowing) the linkage is out of adjustment under the top cover below the seat. You can either have a New Holland dealer adjust it or if you won't be plowing flip the lever 90 degrees to position control (for using most 3 pt. equipment).
