Order Ford 800 Parts Online
Ford 8000 Serial # Location?
Arnettbros
02-24-2008 04:48:11
Can someone tell me where I can find the serial number on my Ford 8000 diesel? Thanks
Cloud
02-24-2008 13:15:58
 Re: Ford 8000 Serial # Location? in reply to Arnettbros, 02-24-2008 04:48:11
Arnettbros,
According to my supplements, the location to find your stamped serial number on your Ford 8000, they would be Stamped on the upper, rear area of the center housing behind the HPL cover.
I"m sorry but I do not know what HPL means, but,I am sure you can figure this out.
I hope this helps.
Be safe,
Cloud
RickB
02-24-2008 13:50:21
 Re: Ford 8000 Serial # Location? in reply to Cloud, 02-24-2008 13:15:58
English version: Upper rear of the rear axle center section just below the hitch cover. Inside the toolbox has to be the dumbest place anyone ever fastened a data plate.
Old Ford Mechanic
02-24-2008 20:33:38
 Re: Ford 8000 Serial # Location? in reply to RickB, 02-24-2008 13:50:21
I agree Rick,it was one of adhesive versions also.Stuck on the inside of the door.I'm not positive they had the serial info on that one.But i know it had the unit # and such.Same thing they had stuck under the right side hood panels on the thousand series tractors.
Old Ford Mechanic
02-24-2008 07:27:05
One place to look is on the inside of the toolbox lid above the step on the leftside of the tractor.I'm not sure of the stamped location.
