center bolt
drk forsyth
02-24-2008 14:54:07
I would like to find a center bolt for a oil filter for on a Jubilee. I can't find the part number and CNH says its out of production. I would like to keep the tractor origional and I'd like to find a used one. If anyone has one or knows of one, please let me know
Jim.UT
02-25-2008 15:01:27
 Re: center bolt in reply to drk forsyth, 02-24-2008 14:54:07
I found the part number in one of my books. It's 66741. The official description is "Bolt & Valve Assembly - Oil Filter Center". Good luck in your search!
soundguy
02-25-2008 05:59:36
If you get jims rounded off bolt.. you can always weld or braze it up and then grind new flats on it. or weld a nut to it... the former, probable making it look the best.. etc.
soundguy
Jim.UT
02-24-2008 20:36:02
I have one, but the hex part is in bad shape. The internal part is fine, but someone has rounded off most of the corners on the hex. Can't get a wrench on it. Have to use Vice-Grips or a pipe wrench to remove it. I'm replacing it with another used one I got from someone who did a spin on conversion as already suggested.
You're welcome to my old one for the cost of shipping (probably $2) if you can't find a better one.
Bendee
02-25-2008 00:33:33
 Re: center bolt in reply to Jim.UT, 02-24-2008 20:36:02
Could the hex be slightly taken down with an angle grinder to fit maybe a smaller socket.??
Jim.UT
02-25-2008 10:46:06
 Re: center bolt in reply to Bendee, 02-25-2008 00:33:33
Yeah, probably. But I'm not the kind of guy that has much success doing that and having it come out even....you know a perfect hex rather than some misshapen mass that's worse than what I started with.
RickB
02-24-2008 15:24:41
 Same part '53 to '59 in reply to drk forsyth, 02-24-2008 14:54:07
One of you guys who has done a spin-on conversion, step up!!
