1979 Ford 555 fuel pump
beerbudget
02-25-2008 11:47:36
Anyone know where I can get a fuel pump for a 1979 Ford 555 Backhoe 3 cyl.Having no luck searching. Thanks!
RodInNS
02-25-2008 13:20:19
 Re: 1979 Ford 555 fuel pump in reply to beerbudget, 02-25-2008 11:47:36
Is there a particular reason that you can't rebuild the one you have?
If you can't then a pump for a 4600 tractor is set the same. Pumps from a 4100, 3600, 2600 and probably those same variants from the 10 series could also be fitted if you up the delivery specs on those pumps. It's just a CAV pump. There's absolutely nothing special about it.
Rod
