Order Ford 3000 Parts Online
3000 power steering pump
hugh
12-29-2001 16:39:45
My 3000 has an integral pump and reservoir on the power steering. I'm not sure I put the reservoir back on right. Can anyone tell me what position the filler neck should be in. The I&T shows it straight up and down. But then it would be under the generator. On the other hand where mine is now it doesn't look like the filter is being covered with oil. Looking from the front of the tractor mine is in about the 1:00 position. In any case my power steering ain't working so any help is appreciated.
RickB.
12-30-2001 05:38:54
 Re: 3000 power steering pump in reply to hugh, 12-29-2001 16:39:45
That is just about right. The filter is a return filter, not a suction filter. It is not normally submerged. Fill the reservoir till the oil runs out the filler. Recheck after cycling the steering. Pressure testing is next.
