Lots of good thoughts but its decision time. Decisions are subject to change of course: The seals between the chambers apparently don't leak as transmission is low, hydraulic chamber varies per cylinder extension, rear diff is on the money. Each chamber can have its own flavor of oil. 80W90 is readily available whereas 80/90 or 80 requires a 45 mi trip so I looks like 80W90 goes in the transmission, labeled hydraulic oil goes in the hydraulic chamber and 80w90 in the differential. If the chambers start to mix then universal oil will go in all three until the seals are replaced. As for NH 134. I put a Jackson Power Steering Unit and original power steering pump on the tractor. I use NH 134 in the power steering pump per Roland Jackson as his systems are built to be used with a loader pump and thus hydraulic fluid. The same spec oil comes's in an Orange Bottle for my Kubota G1800 lawn mower's hydrostatic drive but the 134 labeled bottle is cheaper and works ok. Rotella 14w40 in the engine, is that ok? When I was a kid (5 y/o when the 861 came off the line in 1960) Quaker State v Penzoil v Havoline v Gulf v etc. was the big debate. 20w in winter 30w or 40w in summer, Straight v multiweight, etc. etc Rotella does make a 10w30 labeled for diesels which has to go into the little Kubota diesel as the engine valleys are too small for 15w40 throughly to get into and adequately lubricate the engine while transfering heat to the water jacket. Now the next big question: On the 80w90 oils there is a GL4, or a GL5 specification. Early 1950's john deere's mentioned a GL 1 or GL3 spec. What's the difference between the GL's? Do the GL #'s make much of s difference? Does the newer GL5 supercede GL4,GL3, etc., and work just as well as the older oil?
