Identifying Old Ford Backhoe
Bill Novacek
03-01-2008 10:10:26
I recently bought an old Ford backhoe. Would like to positively identify so I can order repair manual and parts. It appears to be either a 2000 or 4000 tractor from '62-'64 with Ford loader and Wain Roy hoe. 4 cyl. Shermon high/low 4 spd trans. A number from upper right corner of trans reads as follows; NCA-12517-S-A. Can anyone help me pinpoint just what I have? Thanks
Bill Novacek
03-03-2008 07:16:59
 Re: Identifying Old Ford Backhoe in reply to Bill Novacek, 03-01-2008 10:10:26
Well I scrubbed the serial # area and I found the other 2 digits as well as the first diamond. Badly corroded. First # appears to be a 5. Second either a 6 or 8. Suffices to put me in 1964. This correspond to date on top of radiator,7/64. Thanks for all the help!
Tom Stalker
03-02-2008 06:56:53
Here's some great info. on your Sherman. I'll pass on an important note given to me by John_Bud, NEVER shift the Sherman tranny while the tractor is moving!!
Sherman Transmissions
john_bud
03-01-2008 18:21:02
Well, for one thing you have the wrong side of the tractor for the model # !
If you squat down on the left side of the tractor and put your left hand on the starter and your right hand on the clutch peddle - right in front of you is a bulgy area where the starter attaches and the flat spot on top of that has the model number and serial number.
(Credit to Old for the description !)
Bill Novacek
03-01-2008 18:58:22
 Re: Identifying Old Ford Backhoe in reply to john_bud, 03-01-2008 18:21:02
Thank you all for the ID link. The model # is 41300S. Thus it is a 4000 series built after 8/62. An industrial model. 4 spd trans without PTO. I'm not sure what the S stands for. Maybe Shermon Trans? The serial# is a little confusing. It reads "132" with a square turn 45 degrees. Should I assume that means 1320?
john in la
03-02-2008 03:07:11
 Re: Identifying Old Ford Backhoe in reply to Bill Novacek, 03-01-2008 18:58:22
Yes the S stands for factory installed sherman trans.
john_bud
03-01-2008 19:09:39
You may have to wire brush the area down clean to make out the rest of the numbers. The 45 degree square is called a diamond and it signifies the start and end of the serial number. So, the last 3 digits are known, there is at least 1 more digit, probably 2.
1962 started at SN 1001
1963 started at 11948
1964 started at 38931
Tom Stalker
03-01-2008 17:28:43
Try this link to ID your tractor
ID link
Tom Stalker
03-01-2008 17:28:37
ID link
wpn
03-30-2008 09:56:57
 Re: Identifying Old Ford Backhoe in reply to Tom Stalker, 03-01-2008 17:28:37
I have an old ford backhoe the looks like model #342 and looks like serial No. 0141. Tha batery acid's gotten to it. Can you tell me anything about this unit ? Thanks. Bill
