3550 3500 select o-speed
derryspring
03-02-2008 18:31:53
i have a 3550 ford backhoe with the sos trans and it sat for about 8 years and it will go in to foword but does not go in to reverse ive been told somethin is frozen but im not sure what it is and i dont want to screw it up if some one could help please
Larry NCKS
03-02-2008 19:34:34
 Re: 3550 3500 select o-speed in reply to RWK in WI, 03-02-2008 18:31:53
more info!!!!! does it operate properly in all forward ratios and go to neutral in both reverses?
john_bud
03-02-2008 21:57:27
 Re: 3550 3500 select o-speed in reply to derryspring, 03-02-2008 18:31:53
Not to sound like an AH, but you should first buy a manual for the selecto. Next the heat it up good and change the SOS filter and fluid. Then follow the book for adjustments.
It's possible that there is just varnish on the control valve elements or a band out of adjustment. But, I'm no SOS expert - just the basics for any new piece of equipment that has sat.
jb
