I'm in the house and all my stuff is in the shop or under the sheds. It's 40, front blowing through and we just had 2 inches of rain so I'm going to stay in the house for now and guess. I get Roosa's and CAV's mixed up some times. Since you start on starter fluid everything but fuel delivery must be ok. First you do have adequate available fuel in the tank..... Then, I'd go to the pump where the fuel line enters and crack it insuring that you have a not-interrupted source of available fuel there (since you already did the filters). Then, on the side of the pump should be (remember I'm trying to remember) a screw or a screw/nut that is in the side of the main pump housing and is just sitting there; obviously it's not trying to attach anything to the pump; also it will be small, 3/8" or less, maybe a lock nut and a slotted screw rather than a hex head screw. It is not the one that is wired and sealed....that one is for flow and you want to leave it alone. Crack that one and turn engine over till you get solid fuel. Then since you are having such a problem, go to the outlets of the pump and crack them. Crank till you get fuel. Then move down to the injectors and do them. If wrong, later on today I'll be going out to feed and will look and correct any errors I may have made. My Fords start with '63 models (2000, 3000, 4000) and they use CAV distrubutors. Sure yours isn't a CAV. They look a lot like a Roosa distributor pump. Mark
