Order Ford 4000 Parts Online
Hydraulic pump on 62 4000
Balatonm
03-10-2008 06:31:50
I was mouving snow with my 4000d friday, and (I think) the hydraulic pump whent out, but ime not sure. It has plent of hydr fluid and the 3point won't mouve at all. Neather will the loader.
Any other Ideas, you MN guys know how march can be. PS.I let the tractor idale for 30-35min like usual before I started mouving snow.
RodInNS
03-10-2008 14:12:43
 Re: Hydraulic pump on 62 4000 in reply to Balatonm, 03-10-2008 06:31:50
Assuming that there is oil shooting out the pump bleeder when you open that while cranking it over... I'd say there is a problem with the unload valve on the underside of the lift cover. That style of tractor was well known for that around here. It hangs 'open' and unloads the pump flow rather than directing it to the lift cylinder.
Rod
Balatonm
03-10-2008 12:29:07
I tried holding them up with the lever up and the tractor at about half thraghtale, and they didn't presurize any.
Balatonm
03-10-2008 10:49:58
I'll try that when I get off work, Any thing else I should try, and yes it is a 4 cly.
I also noyiced that I can lift the 3point arms easily with one hand, and they havent fallen any with the blade off. Hope this helps some.
soundguy
03-10-2008 12:15:11
 Re: Hydraulic pump on 62 4000 in reply to Balatonm, 03-10-2008 10:49:58
Being able to lift the arms is normal.. there is no hard connection between the cyl / piston / rockshaft dogbone. If it stayed up, did you have the lift lever up and pump running, so it pressurize dthe cyl with no load on it?
soundguy
soundguy
03-10-2008 06:39:00
Assuming this is the 4cyl style.. ( essentially an 801 tractor.. etc.. ) Loosen the bleed/burp plug out of the top/front of the pump and see what ya got..
soundguy
