Order Ford 4000 Parts Online
1964 Ford 4000 LP 5 Speed Input Shaft
richardp3
03-10-2008 16:02:56
third party image
third party image
I have a broken input shaft oil seal holder. It also functions as the slide tube for the clutch release bearing (#2 in the parts diagram attached). Anyone know of a good used parts yard I can contact?
awhtx
03-10-2008 21:03:12
 Re: 1964 Ford 4000 LP 5 Speed Input Shaft in reply to richardp3, 03-10-2008 16:02:56
I got a sliding coupler for my 5 speed from Alexander's Ford Tractors in Winnsboro, TX. Reasonable price and UPS delivered it the next day with Ground shipping.
richardp3
03-10-2008 21:28:22
 Re: 1964 Ford 4000 LP 5 Speed Input Shaft in reply to awhtx, 03-10-2008 21:03:12
Thanks awhtx. I'll call them tomorrow.
Did you have any difficulty swapping it out? I don't want to pull the tranny apart. It looks like the top bolts may fall into the transmission housing when I remove the nuts from the clutch side.
awhtx
03-11-2008 06:38:34
 Re: 1964 Ford 4000 LP 5 Speed Input Shaft in reply to richardp3, 03-10-2008 21:28:22
It was about 3 years ago when I had mine apart so I don't recall exactly but I would bet that if you see nuts holding that housing to the trans case then there are studs screwed into the case and not bolts that go all the way through. Lossen one of the nuts and you'll be able to tell if it's a bolt or stud.
john_bud
03-10-2008 20:05:36
Now how did that get broke? Gotta be a story behind it !
jb
richardp3
03-10-2008 21:13:45
 Re: 1964 Ford 4000 LP 5 Speed Input Shaft in reply to john_bud, 03-10-2008 20:05:36
Well, there may be a story, but it will forever be a mystery. I picked up this tractor to rebuild. It ran and operated well, but was butt ugly. The clutch must have been operating this way for a long time because the clutch has date marks of Aug 94. My guess is the last clutch fell apart and broke the coupler. A previous owner probably repaired the clutch and decided to take his chances on this part.
soundguy
03-10-2008 16:45:18
Probably the same part as the other 5 speeds the tractor shares it's heritage with.
Wengers is a good salvage yard.. however I'd email John smith first.. he has plenty of odds n ends laying around.
soundguy
