Powermaster fuel gauge or not?
BZ
03-11-2008 16:09:24
I looked at my dash, and I have amp, temp, oil pressure. I also have a red light that is not hooked up. I would like to hook the fuel gauge back up and get it working, but dont know which gauge to give up. I suppose back when it was built, the red light would lite up when it was not?, charging? The tractor has been converted to 12 volts, was wondering how I could utilize the red light as charging, and then use the 2 inch hole for my fuel gauge? What are some opinions?
Thank You,
BZ
soundguy
03-12-2008 07:32:11
 Re: Powermaster fuel gauge or not? in reply to BZ, 03-11-2008 16:09:24
Yep.. like Rick ( and others )said.. wire the lamp to the #1 terminal on the alternator if it is a delco 10/12 SI model.. then loose the amp gauge and stick the fuel gauge there..
soundguy
Bendee
03-11-2008 22:04:04
The light is there so remove the amp meter,red light is as you say. out when charging.
NWMO 901 SOS
03-11-2008 19:48:01
 Re: Powermaster fuel gauge or not? in reply to Larry NCKS, 03-11-2008 16:09:24
I just installed a charging light on my 971 and personally prefer the light to an ammeter, though there are arguments for both sides. My fuel guage is not functioning and I hope to fix it in the future. A new guage is not too bad, but if the sending unit needs replaced, it's a little more spendy from most places. It does seem I found it for around $60 (about 1/2 of most sites) somewhere, but I would have to check my favs to see if I could find it. I haven't spent much time on it, but I did beat on the sending unit some, trying to spin it in the tank to remove it. No luck at all and I had other fish to fry. Best of luck and keep us posted.
Chris
Larry NCKS
03-11-2008 18:31:03
 Re: Powermaster fuel gauge or not? in reply to The JD Workmen, 03-11-2008 16:09:24
if they had a red light from the factory, they didn't have a factory ammeter.
RickB
03-11-2008 17:05:11
Wire the lamp into the alternator's excitation circuit (field) and the lamp will work as designed.
BZ
03-11-2008 17:30:46
 Re: Powermaster fuel gauge or not? in reply to RickB, 03-11-2008 17:05:11
Hey, Thanks, thats what I will do. BZ
