Order Ford 800 Parts Online
Non-running 800 series
46Chev
03-12-2008 07:20:52
Anyone know the going rate for a non-running hundred series tractor. I discovered a likely restoration or parts candidate that has been parked for several years. It looks as if the tires are down and the rear rims have severe rust. From what I could tell the sheet metal was clean. It looked like lights, emblems were missing. I'd like to make a fair offer for it if the owner wants to part with it. Sorry that's all the info. I can give without getting permission to look at it.
john_Bud
03-12-2008 20:00:46
 Re: Non-running 800 series in reply to 46Chev, 03-12-2008 07:20:52
soundguy said:
Remember.. it's ring gear may be shelled out, have leaky seals all around, no breaks, chipped teeth in the tranny, and spun bearings on a ruined crank with holes in the piston and a cracked head, bad lift pump and non working lift cyl parts.. and leaky hyd plumbing thru the tranny casting... when buying a non runner.. you are only sure you are getting the stamped metal and the bare castings... just what ya see.. everything else is a mystery..
soundguy
A regular Mr. Sunshine you are!
The problem I've had is that everyone thinks they have a show room perfect tractor that was parked in a climate controlled underground bunker filled with Nitrogen and not some clapped out rusted up hunk that was drug over to the weeds after blowing 3 rods out the side of the block!
jb
Bendee
03-13-2008 06:08:03
 Re: Non-running 800 series in reply to john_Bud, 03-12-2008 20:00:46
Couldn't you have made that post without the ridicule.?
old
03-12-2008 08:17:15
A lot depends on where you are and the price of scrap iron in your area. Scrap iron prices have drove up the valve of old tractors just because of weight. I pay $200-500 for one like that in my area but it can be more at times
soundguy
03-12-2008 07:40:43
500-700 for a non runner. You have no idea of the internals.. or the trans.. or the hyds.. I fit had particular minty parts on it.. or items i needed, and it lookedlike it could run.. or ran when parked.. perhaps as high as 1000$ if it had good oil and all fluids were good, and had compression.. etc..
With yours with rotten tires and needing rims.. I'd be onthe low side.. say 600$ maybee..
soundguy
46Chev
03-12-2008 08:15:37
 Re: Non-running 800 series in reply to soundguy, 03-12-2008 07:40:43
I was thinkin' about $500. Thanks for pointing out that the innards may well be scrambled! Could be quite a checklist to go through before an offer. Most sellers don't like you tinkerin' an takin' stuff off for inspection so it could be a hard call on that level.
Brian in MA
03-12-2008 08:45:14
 Re: Non-running 800 series in reply to 46Chev, 03-12-2008 08:15:37
Some don't mind. I bought an 8N years ago that engine was siezed when I approached him. I made an offer based on the tractor running. Then I spent a weekend getting it running in his yard and drove it home. I agree, some don't even want you to knock on their door and ask about a tractor that has been sitting for years.
soundguy
03-12-2008 10:55:26
 Re: Non-running 800 series in reply to Brian in MA, 03-12-2008 08:45:14
Yep...
I've passe dby a house with a whole yard of implements rusting away in the back of it.. along with an old industrial ford.. guy used to have a big 6xxx JD tractor he pulled a 12' disc with.. but the tractor has been gone for years... I stopepd and left a message on his fence gate asking about a couple implements if he wanted to convert them to cash.. still waiting for the phone to ring1
soundguy
larry cook
03-12-2008 19:06:08
 Re: Non-running 800 series in reply to soundguy, 03-12-2008 10:55:26
left a note taped to a gate once asking about a N once. fellow called me and gave me the history of it and his whole family i think. learned alot that day, last thing i learned was that he was not selling and never would, he just called to tell me so.
larry cook
soundguy
03-13-2008 05:14:05
 Re: Non-running 800 series in reply to larry cook, 03-12-2008 19:06:08
Dang.. teased you and strung you along just to let you down in the end!
soundguy
