Order Ford 4000 Parts Online
4000 hydraulics
Balatonm
03-13-2008 06:34:02
OK, I bleed the hyd, no problum, but still no lift at the 3-point or the loader. I can hear the pump runing and left the 3-point bloked up for about an hour still no pressure. Anything else I should try? I would perfer not to have to replace the pump unles I have to.
thanks Balatonm
Balatonm
03-13-2008 08:13:16
 Re: 4000 hydraulics in reply to Balatonm, 03-13-2008 06:34:02
Its a four cly, and yes I did get some fluid when I bleed the hyd. I havent been to the parts store for a presure gauge, i'll get one tonight.
soundguy
03-13-2008 07:10:40
I can't remember the 1st post.. but is this a 3cyl or 4 cyl model.
did you get oil out of the pumnp when bleeding?
have you slapped a gauge on the option cover and chained the arms down to see if yuo are building pressure ( or into a remote then deadhead it.. etc.. )
soundguy
