Wedge; Here's a test for your genny output. 1. Disconnect the armature (red) wire from the terminal on the generator. Connect a jumper wire across the armature and field terminals. 2. Connect the negatve lead of a 0-75 ammeter to the generator armature terminal. 3. Connect the other ammeter lead to the terminal of the armature wire. 4. Start the engine and gradually increase the engine speed to 1500 rpm while observing the ammeter. The generator output should reach or exceed 20 amperes. NOTE: Stop the engine and disconnect the jumper wire from the field and armeture terminals as soon as the generator output is obtained to prevent overheating the generator. 5. If the generator output is below 20 amperes or is erratic, check the generator belt tension and adjust if necessary. Repeat the test. If adjusting the belt does not increase the generator output to 20 amperes, remove and repair or replace the generator. If you need a test procedure for the VR post back. Hope this helps.
