I don't believe it . . . I flat out don't believe it!!!!!
Larry NCKS
03-19-2008 10:56:45
Opened up the SOS on Commander 6000 this morning. Matter of fact need to get dinner yet because my curiosity just had to be satisfied.
Wire was broke off the safety starter switch. Guessing that's what you'll find too, Dave.
Dang thing was cranking in neutral because somehow one of the cams pinched the wire just right to ground the starter switch. Anyhow it has a bright shiny copper spot mid-wire and the break from the switch appears to be old. Could have just as easily cranked in any other spot the way it looked. It just happened to choose neutral.
Now if the safety starter switch is good. :lol:
Bet none of us would have chosen this finding in a million years.
Bobrh
03-20-2008 10:33:33
 Re: I don't believe it . . . I flat out don't believe it!... in reply to Larry NCKS, 03-19-2008 10:56:45
I could tell from reading lots of your posts you would not let this thing ride without looking into it. Cause like me if it isn't right - it isn't right and drives one up a tree until the mystery is solved. Good catch and great thing to know about SOS. I have 5 of them and never would have thought about a broken wire getting caught up in a cam.
Bendee
03-19-2008 23:00:04
First thing everyone would have suggested!!
Larry NCKS
03-19-2008 17:50:45
 Re: I don't believe it . . . I flat out don't believe it!... in reply to soundguy, 03-19-2008 10:56:45
Likely fatigue and getting pulled on by the cams. Coating inside tranny was brittle and cracked.
NWMO 901 SOS
03-19-2008 12:42:57
 Re: I don't believe it . . . I flat out don't believe it!!!! in reply to Larry NCKS, 03-19-2008 10:56:45
Thanks for updating us Larry. Glad you found the problem and should be a pretty easy fix. Tractor Gods were being kind having it only start in nuetral. Your case points to the benefit of figuring it out and fixing it vs. "lettin it ride". Had to have been close to starting in gear as well. The first time can be the wrong time and someone get hurt or worse. Good work.
Chris
kcred
03-19-2008 12:29:44
If the break was old , what would have caused it to break ? Bad connection on the switch itself ?Red
sotxbill
03-19-2008 11:00:47
The ole sos was just showing its respect for you.
but turn your back and it'll as soon kick you in the butt. lol... Bill
