injection pump
WMKoch
03-23-2008 06:32:56
Is there a kit for rebuilding the injection pumps for the old four cylinder deisels or a good reasonable place to send them to be rebuilt?
Larry NCKS
03-24-2008 15:40:58
 Re: injection pump;heyLarryNCKS in reply to Rick Kr, 03-23-2008 06:32:56
yep should come in kit. I doubt if this is your white smoke issue though.
WMKoch
03-24-2008 13:32:37
 Re: injection pump in reply to WMKoch, 03-23-2008 06:32:56
Thanks guys, I'll see what comes up.
Larry NCKS
03-23-2008 14:06:51
 Re: injection pump in reply to twopop, 03-23-2008 06:32:56
the original governor retaining ring is plastic.
the updated is not and should never fail and cause the pump to act up again.
Kents671DKS
03-24-2008 07:16:17
 Re: injection pump;heyLarryNCKS in reply to Larry NCKS, 03-23-2008 14:06:51
Not to hijack a topic, But could you tell me if the governor retaining ring comes in the kit or is it extra. I bought a kit from the guy on e-bay(took his number down and called him) but I didn't know to ask him until after looking back through archives before I tear down my pump. mine doesn't act up, just a lot of white smoke at startup that goes away after a while and she leaks a lot around the g shaft. thanks, Kent
awhtx
03-24-2008 12:21:17
 Re: injection pump;heyLarryNCKS in reply to Kents671DKS, 03-24-2008 07:16:17
It comes in the kit. I bought one from him.
bjr
03-24-2008 08:12:27
 injection pump; Me Too in reply to Kents671DKS, 03-24-2008 07:16:17
Mine, early 4 cyl 4000 diesel with the DB Stanadyne pump, smokes on start up and then clears up also. Ran some Stanadyne fuel treatment through it and seemed to help while it's in there but when it's gone, back to old smokey. My pump also has the touchy throttle problem where there's not much movement from idle to full rpm's. Would orings kit help me? I was thinkin' maybe injectors maybe needing service, but what a PITA to get to them. There's a web Company called Real Diesel that's supposed to only charge $250 a pump to rebuild, but they are not accepting anymore pumps according to there site. Anyone have experience with them?
Larry NCKS
03-23-2008 11:35:31
 Re: injection pump in reply to RodInNS, 03-23-2008 06:32:56
Yep depends on what's wrong with them. Mostly it's a disentegrated governor retainer ring. You can buy the kit from any diesel shop for less than 40 dollars that'll fix this. If you want to update to the new style governor, add 60 dollars or so.
Abnormal
03-23-2008 13:17:16
 Re: injection pump in reply to Larry NCKS, 03-23-2008 11:35:31
Two questions,
1. Ain"t the governor retaining ring plastic
2. What will the new type governor do for me?
Thanks for your help. I've learned a lot just reading everyones posts.
john_Bud
03-23-2008 08:12:12
WMKoch said: (quoted from post at 06:32:56 03/23/08) Is there a kit for rebuilding the injection pumps for the old four cylinder deisels or a good reasonable place to send them to be rebuilt?
I found a guy from AL that sells on e bay. Seal kit was about $25 or 30. The seller is "jbass195"
Stanadyne Roosa Master Diesel Injection Pump Kit 24371
Abnormal
03-23-2008 07:01:46
If you find either a kit or someone to rebuild reasonably let me know. Mine is acting like a spoiled brat.
