1996 Ford F-150
Charles Story
01-04-2002 17:54:15
I know this is not the right place to be asking questions about a P/U truck but I am a wits end. I changed the clutch, pressure plate, throw out bearing, slave cylinder and clutch master cylinder. My question is what is the best way to bleed the air out of system. I was told by a mechanic that it will take a long time just keep pumping pedal???? All help appreciated.
kb
01-06-2002 12:52:35
 Re: 1996 Ford F-150 in reply to Charles Story , 01-04-2002 17:54:15
Charles, When I have put on master cylinders I made some bleeder hoses, (some rebuilt and new master cylinders come with them). To make the hoses I get fittings to match the MC and have about 3 inches of solid line on them, with about 8 inches of extra rubber tubing extended beyond that. To bleed I bolt the MC into place, attach my lines, and fill the reservoir while elevating the lines. Then I stick the ends of the rubber hoses into the MC reservoir and have someone pump the brakes, when the bubbles stop the air is out. I then connect the regular lines to the MC.
To get the air out of any remaining lines I bleed the system at the bleeder valves on the cylinders. Pump up the brakes, loosen the valve while the brakes is being held down (this forces the air out), retighten and release the pedal. Continue the process until the cylinder is bled, then do the others.
I've never had any luck bleeding air by pumping the brakes with the reservoir cap off. I have managed to get air in my lines by using that method.
I have heard of some that will pump their brakes, then remove the lid with the pedal held down, replace the lid, then release the pedal. The air is supposed to be displaced by the fluid in the system and makes its way back to the MC, and when the lid is removed it escapes. I've never personally used this method, so I am unsure how dependable it is.
jdp
01-05-2002 14:31:53
I found the easiest and fastest way to bleed the clutch is to buy a cheap oil can and fill it full of brake fluid. Get a piece of hose that fits tight on the bleeder screw and the oil can nozzle. Open that screw and pump until no more air comes out of the top, and don't forget to take the cover off the resivoir. Shut the bleeder and you are done. Works evrytime for me. That guy at the parts store is on crack.
Jim K
01-05-2002 07:38:08
If you really think about what you are trying to do is force air bubbles to sink or flow downward
This defies the laws of nature.
Bleed the system as best you can through the bleeder screw and then by pumping the pedal and over the next few days the remaining air will rise out of the system. Unless you have a way to force fluid into the system from the bleeder screw
causing all air to rise out through the master cylinder. Be patient, good luck Jim K
Jim
01-04-2002 19:16:12
If the slave cylinder should have a bleed valve on it. It not, I guess you'll have a lot of pumping to do!
Charles Story
01-04-2002 19:28:08
 Re: Re: 1996 Ford F-150 in reply to Jim, 01-04-2002 19:16:12
It does but auto parts were I purchased kit, advise not to bleed just pump. I thought this was a little off base. I will use bleeder valve. Appreciate advice.
