Order Ford 4000 Parts Online
1964 ford 4000 sos
andyinNC
03-27-2008 18:18:43
I need a wiring diagram for a 64 ford 4000 sos with a 12 volt one wire alt.
NWMO 901 SOS
03-28-2008 22:29:52
 Re: 1964 ford 4000 sos in reply to Illini Ford, 03-27-2008 18:18:43
andyinNC said: (quoted from post at 20:18:43 03/27/08) I need a wiring diagram for a 64 ford 4000 sos with a 12 volt one wire alt.
Good evening Andy,
If you look at MTs post on this same page, Glen has posted a link to a page by a talented tractor fellow who has provided some great diagrams. I didn't see one to match your exact scenario, but this should be close. Are you still using the transmission lubrication sending unit indicator? If so, it is not shown, but would need power from the keyed side of the terminal block and then the wire to the sending unit. With no pressure the switch is closed and provides a light. When started and more than 2psi, light is extinguished. At any rate, I hope this helps and thanks to John in La for the wonderful diagrams.
third party image
Chris
Joe(TX)
03-28-2008 08:12:53
 Re: 1964 ford 4000 sos in reply to andyinNC, 03-27-2008 18:18:43
Look here.
andyinNC
03-28-2008 18:41:49
 Re: 1964 ford 4000 sos in reply to Joe(TX), 03-28-2008 08:12:53
I really couldn't find a wiring diagram for a 12 volt system on here. I found some info but not a diagram
