Need Voltgae Regulator 6V , 1964 and Ques. about Model #
JSkolits
04-03-2008 09:08:27
Couldn't fing a 6V regulator for my Ford 2000. Called the parts dept at Yesterday's Tractor and they don't have one. Where can I find one?
Also, the two numbers stamped on my tractor is 21201 and 42981. I believe the second is the Serial#. What is the first? Is it a lot# or is the Model number really 21201 and not 2000.
John :?:
souNdguy
04-03-2008 11:30:08
 Re: Need Voltgae Regulator 6V , 1964 and Ques. about Model # in reply to JSkolits, 04-03-2008 09:08:27
If your 2000 is the 4cyl with the ford generator and 3-tab regulator, which i believe it is, since it is 6v.. then ANY NAA, X00 or X01 6v regulator for the models I mentioned will work as they are all b-circuit and 3-tab.
Soundguy
John Skolits
04-03-2008 18:05:20
 Re: Need Voltgae Regulator 6V , 1964 and Ques. about Model # in reply to souNdguy, 04-03-2008 11:30:08
Yep, 4 cyl, 3 tab generator. Thanks.
soundguy
04-03-2008 19:39:43
 Re: Need Voltgae Regulator 6V , 1964 and Ques. about Model # in reply to John Skolits, 04-03-2008 18:05:20
good luck with it.
If you have any problems post back.
soundguy
