Order Ford 2000 Parts Online
ford 2000
7 MAG
04-04-2008 07:40:49
I HAVE A 63 2000 GAS WHEN EVER I GO DOWN A HILL THE TEMP GET UP TO ABOUT 220 F AS SOON AS YOU GET ON THE FLAT IT DROPS BACK DOWN NEW T STAT FLUSHED RADIATER ANY HELP HERE POSIBLY RADIATER CAP? THANKS
7 MAG
04-04-2008 08:01:24
 Re: ford 2000 in reply to 7 MAG, 04-04-2008 07:40:49
FLUID LOOKS GOOD CAN MOW OR PUSH SNOW ALL DAY ONLY SHOWS WORM IF GOING DOWN HILLS
Fordfarmer
04-04-2008 07:47:56
The temp sensor is at the rear of the head... sounds like it may not have coolant around it when you're going downhill. How is the coolant level? Only thing that comes to mind right off... or maybe the pump isn't working so great, and doesn't keep the coolant circulating when the rear of the engine is higher than the front?
