DIESEL
BOB PA.
01-06-2002 16:41:12
HAVE A 841 FORD 1958. I HERE THERE IS #1 DIESEL AND #2 DIESEL CAN ANY ONE TELL ME WHAT IS BETTER TO RUN.AND WHAT IS DIESEL #1 THANK YOU ALL. BOB
Ev
01-08-2002 12:05:16
 Re: DIESEL in reply to BOB PA., 01-06-2002 16:41:12
If you regularly get temps. below 30 you may want to used a 50-50 blend of #1 and #2 to prevent fuel jelling (plugs the fuel filter) and to make starting easier. It's a must for most diesels in northern Wisconsin between Dec and March.
LarryNCKS
01-08-2002 09:44:19
the down side of #2 is that it will gel (freeze) in temps as high as 10F if it's poor quality. #1 has lower cloud and gel points. In the winter in North Central Kansas we like to have them mixed 50:50 ratio to prevent gel. Not that we've needed it so far this winter.
jdp
01-07-2002 18:18:49
What was said about the lubrication properties is correct. Also, #1 diesel is more refined than #2; which therefore means that #1 diesel has less power than #2.
bob PA
01-07-2002 19:38:10
 Re: Re: DIESEL in reply to jdp, 01-07-2002 18:18:49
thank you all for your input. it was what i needed to no. thank you. BOB
twopop
01-06-2002 19:51:44
#1 diesel is about the same as kerosene and does not have lubricated qualities to use in most diesel injection pumps.everthing that i know of calls for #2 diesel
