Order Ford 5000 Parts Online
new weight bracket for the 5000
Fordfarmer
04-05-2008 09:04:14
third party image
Finally got the new bracket from the welding shop. It's an inch taller than the one from the 4600, since he didn't have any 5" stock on hand. Made from 6 pieces rather than the 4 used in the factory, but not many people are set up to bend 1/2"x5" or 6" steel. I don't know the exact cost of the bracket since I had a bale fork worked on at the same time. $45 in steel. Should have it painted and installed next Mon. or Tues.
soundguy
04-05-2008 21:55:37
 Re: new weight bracket for the 5000 in reply to Fordfarmer, 04-05-2008 09:04:14
Nice!
soundguy
Keith Williams
04-05-2008 10:46:44
That looks great!
I think you will be better off with the flat front. If I remember correctly, when I put the 8th weight on my 7000, the 2 outer weights would be sprayed out just a little because of the bend in the steel. I do not miss lifting those weights up onto my 7000 row crop.
Fordfarmer
04-05-2008 09:05:09
third party image
2nd pic.
