Order Ford 4000 Parts Online
4000 3-point
5000-nut
04-06-2008 19:32:01
Hey does anyone know if it is normal for the 3-point to stop lifting when you use the rear remote? I hook up my semi-mount plow and saw that I had to let the 3-point come all the way up before I could use the rear remote.. any info wold help..
RickB
04-07-2008 04:11:07
 Re: 4000 3-point in reply to 5000-nut, 04-06-2008 19:32:01
Perfectly normal operation of an open center hydraulic system. The valves are in series.
Keith Williams
04-06-2008 20:10:51
My 1964 Ford 4000 is the same way. I do not know about the next generation (1965 - 74) though I would believe they are the same as the remote valves are the same (I think).
Larry NCKS
04-06-2008 19:41:23
 Re: 4000 3-point in reply to Brian in MA, 04-06-2008 19:32:01
not sure! Do remember that on the old 850 if the remote was engaged it robbed oil from 3 point and 3 point would not lift further until remote was disengaged. If you have a prior 4000, I assume it would be the same. If you have a later, I don't know.
