  verticaltrx..... ...you write..... .."3. The rear main seal is basically shot, with it being a 2-piece seal would it be possible to replace it without splitting the tractor? (rotate the old seal out and new seal in around the crank) I've done this on automotive engines, but not sure if it could be done with this engine, any insight?" ..... ....yep, them hi-tech jingle-jangle tranny anti-clog cotter-keys workin' eh? As a general rule, the 2-piece rope crankshaft seal is "semi-bulletproof" and doesn't leak. But the tranny input shaft seal ($3, cheap) LEAKS from OVERFILLED tranny oil. Most trannys gitt overfilled from rainwater thru cracked and rotted tranny shifter boot. ($5, cheap) Probably good idea to drain yer chocolate colored tranny oil. Pull one of yer 6"-plate tranny dipstick bottom bolts and lett'chur overfill drain dribble down the side overnite. That will be yer correct dipstick level. Mark yer dipstick with new level, not all dipsticks are accurate. Lotta dipsticks say full with all cylinders extended. The only cylinder you have is the 1-cup 3-point hydraulic lift, so don't worry about it. Overfilled tranny oil will splash out yer trumpet mouths and greese yer brakes. not good. You write..... .."4. The tractor has a swinging draw bar kit installed but I'm missing the main pin that holds the draw bar in, under the tractor. It appears to use a ~1" dia. pin, maybe 3" long, straight sided with a hole in it. Is there a part number for this or a place where I could find one, or should I just make one out of some round stock?" ..... ...heres pictures of 2-types of swinging drawbar 1"-pins. Mine is still slightly different and uses a linch-pin to lockitt inplace in the SDB clevis hanger under diffy. ($5, cheap) Just go to yer local tractor parts and start wavin' yer hands (grin) Dang, you been lookin' in the archives??? Will wonders never cease. That really pleases me. Recommend you squander $25 (cheap) for I&T FO-19 manual for your new-to-you NAA Jubilee ..... .HTH, Dell
