Steering Gear Housing Lube
Bobrh
04-10-2008 10:50:35
I found the service bulletin on changing the recommended gear lube to "0" grease. It is on page 2 of Utica Sales District Tractor Bulletin #100 Dated October 31,1962. It states that the 0 grease should be used in 601,801,2030,4030 tractors and that it is installed at factory in those models.
I have it scanned but it is a TIF file and won't link up here- any suggestions?
soundguy
04-10-2008 11:59:30
 Re: Steering Gear Housing Lube in reply to Bobrh, 04-10-2008 10:50:35
I can only get page 1 for some reason?
soundguy
Bobrh
04-10-2008 12:07:28
 Re: Steering Gear Housing Lube in reply to soundguy, 04-10-2008 11:59:30
I downloaded the TIF file from the link and when I clicked on page 1 at the bottom it showed page 1 and page 2. I was able to click on 2 and it came up. Did it work for you. Icould not get the JPEG one to work to post it directly.
soundguy
04-10-2008 12:12:48
 Re: Steering Gear Housing Lube in reply to Bobrh, 04-10-2008 12:07:28
The tiff file only shows up as a single page file at 116kb. Shows the same in a viewer or an editor.
soundguy
Bobrh
04-10-2008 12:31:12
 Re: Steering Gear Housing Lube in reply to soundguy, 04-10-2008 12:12:48
Lets try just page 2.
soundguy
04-10-2008 12:37:08
 Re: Steering Gear Housing Lube in reply to Bobrh, 04-10-2008 12:31:12
thanks, that did it.
soundguy
soundguy
04-10-2008 11:56:14
thanks for the link
soundguy
Bobrh
04-10-2008 11:26:38
Trying a Link
Roger in Iowa
04-10-2008 11:22:39
Use JD corn head grease.
Roger in Iowa
