Under the Input shaft (powermaster)
BZ
04-10-2008 13:20:26
I have a 58 powermaster. Since I have the tractor split, I was thinking of replacing the input shaft seal. That doesnt look that hard. Course I have never done one before, but I saw a good post of a fella with very good pictures of his job on here. So, I thought I would try it. My question is, there is a "cap" with I guess 4 bolts on something right under the input shaft. Is that "easily" replaceable? Or am I not wanting to go that far?
Thanks for your help!
BZ
BZ
04-10-2008 21:34:04
 Re: Under the Input shaft (powermaster) in reply to BZ, 04-10-2008 13:20:26
Thanks! thats what I wanted to know. I dont need to get into that!
Thanks!
BZ
john_bud
04-10-2008 21:04:08
That's the end cap for the countershaft. You don't want to mess with it. Unless you want to do more learning about removal of the main gear cluster and how to set bearing preload....
jb
BZ
04-10-2008 19:29:19
Thats what I was wondering, If I was going to do the input shaft seal. Should I go ahead and replace that (PTO) gasket or seal also. Since I dont know whats behind that, I will leave it alone.
Thanks,
BZ
Feron
04-10-2008 17:02:00
If you are talking about the pto bearing cap under the input shaft. You don't want to take that off to replace the seals. You just want to remove the input shaft.
