Order Ford 2000 Parts Online
Headlamp for 1963 2000
Bill Tom
04-14-2008 15:47:22
My '63 2000 gas 4 cylinder had been converted to 12 volt prior to my getting it. The headlights were not changed to 12v and were blown. I looked in my notes and saw that someone had converted a 600 and they used Wagner 4419 12v as a replacement. Will they also fit mine? My light measures 5 1/2 inches across. Thanks
soundguy
04-14-2008 18:23:16
 Re: Headlamp for 1963 2000 in reply to Bill Tom, 04-14-2008 15:47:22
If your shells are the trac-to-lite type.. the wagner 4419 will fit fine.
Please don't use a resistor and a 6v lamp.. that's a horrible way to go about it...
soundguy
Bill Tom
04-14-2008 20:01:39
 Re: Headlamp for 1963 2000 in reply to soundguy, 04-14-2008 18:23:16
The shells are the trac to lite. I've decided to go with the 12 volt 4419's. Thanks for helping Soundguy and John.
JohnIa
04-14-2008 18:09:57
Bill Tom, I don't know about the bulb, But you can put new 6 volt bulbs in with the ceramic resistor from a mopar ignition and they'll work. Cuts 12 volt down to 6 volt, same one they use on the 6 volt ignition when they switch to 12 volt. John
