RIMS
ARCADIAINC
04-19-2008 08:30:21
Have an 1955 860. Locally I can find 24 inch turf tires but not 28 inch. Is it possible to use 24 inch rims on this tractor? Thanks!
karl f
04-21-2008 16:51:21
 Re: RIMS in reply to ARCADIAINC, 04-19-2008 08:30:21
lots of highway mowing tractors have 24 inch rims where the center is a welded part of the rim. you'll need the right offset.
karl f
old
04-19-2008 08:36:31
24 inch rims and tires where an option on that tractor when it was new. You would have to get rims, tires, tubes and center for you to be able to put the 24s on and that would cost alot
ARCADIAINC
04-19-2008 09:01:40
 Re: RIMS in reply to old, 04-19-2008 08:36:31
Thanks Old---May be worth it. My rims etc are about shot. Any idea where to buy tem?
old
04-19-2008 09:25:03
 Re: RIMS in reply to ARCADIAINC, 04-19-2008 09:01:40
This site and or value bilt would have the rims. The centers probably a New Holland dealer or a salvage yard, there not common by the way. You have to have the centers for the 24 inch rims to fit on it. You also might try Miller tires they should have 28 inch turf tires which in the long run would save you a lot of money
