Order Ford 601 Parts Online
601 ford, 134 cid gas, oil leak
601
04-20-2008 08:20:01
I have developed a leak around the spin on oil filter. Not at the filter seal, but in an area that circles the filter male fitting on the block. I "m not sure what this area would be called, it looks like a seal for the screw adapter for the filter to be attached to the block? Only leaks when under oil pressure.
604
04-20-2008 08:40:21
 Re: 601 ford, 134 cid gas, oil leak in reply to 601, 04-20-2008 08:20:01
There is a oring seal under there that will occasionally crack and leak. Just unscrew the center and put in the new seal(check to make sure it did not come loose first). Easy fix.
Wayne IA
04-20-2008 08:53:21
 Re: 601 ford, 134 cid gas, oil leak in reply to 604, 04-20-2008 08:40:21
You probably need a new gasket between the block and adaptor plate. Get the new gasket at your NH dealer.Part Number EAA-6838A.
