Order Ford 600 Parts Online
600 compression numbers?????
604
04-23-2008 17:37:26
Took some readings on a 600 engine I was thinking on throwing in my tired 601. The engine has a little smoke out of the breather at slow speed. So I was worried about blow by. After running for 1/2 hour I got 115, 100, 125, 105psi. Any one know what the acceptable range is? I can't seam to find it in my ford manual any were. Thanks!!!
RodInNS
04-23-2008 19:27:43
 Re: 600 compression numbers????? in reply to 604, 04-23-2008 17:37:26
2 and 4 are a bit low but not too bad. The spread between them and the other two is a bit wide though. Dump a tablespoon of oil in each cylinder and repeat the test again. If the pressure rises then you may have ring issues on the cylinders where the pressure rises. If the pressure doesn't rise then you may have a valve issue.... possibly a tight valve on that cylinder. It's worth a look.
Rod
