Order Ford 8N Parts Online
Ford 48 8N won t run .
Bobby D
04-23-2008 18:39:18
I have a 48 8N that runs great for 2hrs or better , but if I shut it down for 15 min. or so and restart it will only run for about 2min. and stall out. It will not restart for an hour or so and then it will stay running.Anyone ever run into this? It has new points,coil,wires,etc . Thankyou
old
04-23-2008 21:20:39
 Re: Ford 48 8N won t run . in reply to Bobby D, 04-23-2008 18:39:18
You might have a clogged gas tank vent. What might be happening is when its running the fan keeps the tank just cool enough to keep the pressure down so it will run but when shut off the engine heats goes up and causes to much pressure in the fuel line and then you get a no go. Take the gas cap off and see if that help. Could also be a coil going bad but most of the time if thats it, it will only run and hour and then die and not start till its cold again
Bobby D
04-24-2008 03:23:54
 Re: Ford 48 8N won t run . in reply to old, 04-23-2008 21:20:39
Hobby farm , thank you for your reply . The only vents for the tank are in the cap. Is that correct? Bob
old
04-24-2008 08:03:33
 Re: Ford 48 8N won t run . in reply to Bobby D, 04-24-2008 03:23:54
The name is OLD my web site is hobby farm. LOL. The vent is in the top of the tank not the cap. Dirt dubbers love to clog them up and that causes all sorts of funny problem with the way and engine will run. I also agree with what Sound says to check.
soundguy
04-24-2008 05:00:37
The tank came with a vent.. but over the years they can get plugged.
Next time she dies, pull a plug wire and check for spark.. ( if spark is weak.. try jumpering your ignition switch and trying again.. ) if she has spark, pull the carb bowl drain and let it drain into a glass jar.. look for a good flow..
post back.
soundguy
Bobby D
04-25-2008 04:42:28
 Re: Ford 48 8N won t run . in reply to soundguy, 04-24-2008 05:00:37
Thank you OLD,and soundguy for the info. I hope to look at it tonight(Friday) and check the vents and I will go from there. I will let you know how I make out. BobbyD
soundguy
04-25-2008 06:51:22
 Re: Ford 48 8N won t run . in reply to Bobby D, 04-25-2008 04:42:28
unless you can squish down like an ant.. you won't be able to see the tank vent.. it lives under the tractor hood in a non serviceable area, unless you remove the tank from the hood.
soundguy
