Ford 1210 smoking
BillT
04-24-2008 11:05:01
I have a Ford 1210 tractor that has started smoking when started. Black smoke out the exhaust. It seems to have lost a little power, not much because is can still mow and till. I have checked the oil a couple of times now, it does not appear to be burning oil.
Looking at some of the other posts about diesels that smoke, it seems like I should check these things. Can you help with what order I should check them in? Also, any other ideas of what to check before I think about a rebuild?
- fuel in the oil
- carb not getting enough air
- air filter is plugged
- rings gunked up
- valve seals gunked up
Thanks,
BillT
RickB
04-24-2008 14:36:24
 Re: Ford 1210 smoking in reply to BillT, 04-24-2008 11:05:01
They make a lot of smoke for what they are. Most have a horizontal muffler with a front discharge. This is a prefect design for re-circulating the exhaust through the air filter. Change the air filter before you do anything else.
soundguy
04-24-2008 11:38:58
Black smoke on a diesel is unburnt fuel.. I'd check air filter. Could also be overfueling i guess.
if she was pumping oil.. I'd expect to see blue smoke..
Also..diesels don't have 'carbs'
soundguy
BillT
04-24-2008 12:44:32
 Re: Ford 1210 smoking in reply to soundguy, 04-24-2008 11:38:58
Could this problem be related to glowpugs being bad / not working?
-BillT
soundguy
04-24-2008 13:00:24
 Re: Ford 1210 smoking in reply to BillT, 04-24-2008 12:44:32
Lack of glow plugs might make it a bit harder to start.. but once started.. the glow plugs don't do anything.
soundguy
BillT
04-24-2008 12:42:52
How do I check for and know that I am 'over fueling'?
-BillT
soundguy
04-24-2008 13:01:17
 Re: Ford 1210 smoking in reply to BillT, 04-24-2008 12:42:52
get an injector and pump shop to check out the pump and injectors..
soundguy
Brian in MA
04-24-2008 11:51:45
Possibly valve adjustment on one of those engines?
