1953 jub. #S to I D help
raphael
04-26-2008 06:41:26
i have look on the flat & on the front left on the block no i. d. setting on tract. C940-U left side of block. #2on diff.& #2 on tran.A24H on man. right side 12 on tran. 12 on diff.,46B3 on tack,310609 on block, Ishde & NAA7006A on tran,cover on diff. NAA4761A, front axle 56-52-48 with a F in the middle of a maple leaf. on rear axle with a point with 11 points around it. the cyp. in front too. with that all said with my type of input, what does one think i own??
thanks,
regards
r.j.
awhtx
04-26-2008 10:33:16
 Your Jubilee has a 172 cu in engine in reply to raphael, 04-26-2008 06:41:26
310609 is the casting number for the 172 cu in block built in 1958 and 1959 and used in the 801 and 901 tractors. The serial number on those tractors was stamped into the transmission and your Jubilee was probably an early one with the serial number on the block. That's why you don't have a serial number.
ericlb
04-26-2008 07:48:26
 Re: 1953 jub. #S to I D help in reply to raphael, 04-26-2008 06:41:26
look on the bellhousing flat area behind where the srarter mounts, it is there but may be very hard to read, i had to carefully remove 4 layers of paint before i found the numbers on my jubilee it will be stamped numbers[ depressed] not cast [ raised ] numbers
Fordfarmer
04-26-2008 06:53:55
I don't know much about casting codes, but if you have a NAA with no number on the trans. housing or on the block, it's probably an early '53 that originally had the number on the block, but got a replacement block some time in the last 55 years.
