Ford 340 Indicator lights
atk_nut
04-29-2008 12:32:13
Hello,
I just bought a 79 Ford 340 industrial. The ignition switch was taken apart and I had to hot-wire it to get it home. I think I have it put together properly, but there are two lights that flicker intermittently. One is the second from the left and looks like a tapered arrow with a bunch of dots in it and one is on the far right that looks like an upside down key-hole with a tear drop in it.
Any ideas what those lights are? Any ideas why they might be flickering?
Thanks in advance.
RickB
04-29-2008 15:39:40
 Re: Ford 340 Indicator lights in reply to atk_nut, 04-29-2008 12:32:13
The first you describe is the air filter restriction indicator. The second is the low engine oil pressure indicator. They are powered together and a flicker indicates an intermittent short to ground in the circuit or borderline low oil pressure or a borderline plugged air filter.
atk_nut
04-29-2008 21:02:56
 Re: Ford 340 Indicator lights in reply to RickB, 04-29-2008 15:39:40
Thanks!
Anybody happen to have a wiring diagram handy? I'm thinking the oil pressure is ok. From what I hear, the lights been off and on for a while, and it still doesn't miss a beat.
Where will I find the oil sensor and air flow sensors?
Also, what's the big knob on the side attached to the air cleaner for?
Also, was there ever a hot injector on this tractor? (pre-heat) Was one of the wires that I connected to the ignition for that? There seemed to be one extra.
I really need a wiring diagram.
Thanks again.
