Order Ford 5000 Parts Online
Help with engine number, Ford 5000
anders
04-30-2008 11:16:24
Need help figuring out which engine and possible year I have on a Ford 5000, ie 233 or 256 engine.
Found 2 numbers on the left side of the engine, ie same side as injector pump and starter.
First number was on a plate screwed or rivited to the engine. It was kind of hard to read, but my best guess is 3E23N or 3523N or 3S23N. The second letter was the hard to read...
The second number was stamped into the side of the engine, down by the edge of the block.
It reads E522545
Can someone help me figuring out what I have?
RodInNS
05-04-2008 20:11:20
 Re: Help with engine number, Ford 5000 in reply to anders, 04-30-2008 11:16:24
Just reread this post again. Your engine should be a 256.
Rod
Anders
05-05-2008 00:20:43
 Re: Help with engine number, Ford 5000 in reply to RodInNS, 05-04-2008 20:11:20
RodInNS said: (quoted from post at 20:11:20 05/04/08) Just reread this post again. Your engine should be a 256.
Rod
Sounds great Rod! My serial number is E522545. So the E states that it is a newer Ford 5000 engine. Strange that my serial number is missing the date code at the end?
anders
05-04-2008 03:35:01
Found some more numbers.
D1NN 6015B
2BF
T3
2 and a ring with numbers and a pointer to the number 9 on that ring.
tom nelson
04-30-2008 14:31:18
Link
Tom
anders
05-01-2008 09:46:19
 Re: Help with engine number, Ford 5000 in reply to tom nelson, 04-30-2008 14:31:18
Doesnt work for my numbers as I dont have any serial number from the tractor, only engine...
/Anders
RodInNS
05-01-2008 20:32:39
 Re: Help with engine number, Ford 5000 in reply to anders, 05-01-2008 09:46:19
Anders,
I have a service manual for them around here somewhere. I know it has the engine model codes in it. I'll root it out this weekend sometime and look up the numbers. If I don't post it in the next couple days, e-mail me.
Rod
anders
05-02-2008 09:15:34
 Re: Help with engine number, Ford 5000 in reply to RodInNS, 05-01-2008 20:32:39
Sounds great!
