Order Ford NAA Parts Online
NAA and a rotortiller
chester dirt fa
05-03-2008 19:23:13
What is the proper speed at which one should roto-till,and is a 1954 NAA with a 4 speed capable of handling one? thanks
chris777
05-05-2008 21:09:33
 Re: NAA and a rotortiller in reply to chester dirt farmer, 05-03-2008 19:23:13
sorry for the hijack, how would my 961 with the 5speed do ?? is the 5speeds low much lower than the 4speed?
Larry NCKS
05-04-2008 05:32:16
 SOS - the only way to rototill!!!!! in reply to Matt R., 05-03-2008 19:23:13
I'm with the rest of 'em. 4 speed just isn't geared slow enough. The ideal Ford tractor of the late fifties/early 60s for a rototiller is one equipped with a Select-O-Speed transmission, say a 6 or 871 or 81, or an early 2 or 4000. I'd personally pick either an 871, 881 or 4000 because of the added horsepower.
soundguy
05-03-2008 21:37:03
The 4spd trans are just not ideal for tilling. Perhaps in sandy soil.. or if you make multiple passes. It will not be as easy as a modern tractor with a creeper.. or with one of the other trans options..liek the 8spd.. or the howard rotovator gear reduction.. or possible an everet trencher tranny.. both of those slow ground speed, but not pto speed ( post trannies )
soundguy
old
05-03-2008 19:33:37
An NAA has the power to do it but ground speed is way to fast to do a good job. If you where to try it the tiller would be out of the ground more then in the ground. I know because we tried to do it on our 841 and it didn't work worth 2 cents
