Anyone ever seen weights like this?
PatsPOS
05-03-2008 21:05:59
third party image
third party image
So has anyone seen weights like this? I can't find any stampings on it or the other one like it...doesn't mean that something isn't covered by multiple layers of paint. They mount under the fender mounting pads (or above, I guess, if you want to raise your fenders a few inches. And they're HEAVY! I'm no Schwartzenegger, but I can pick up and move about 150 lbs with some difficulty. I can pick these weights up, but I can't go anywhere with 'em! :D
I'd just like to know what I have here. I'm thinking of using these weights in conjunction with a set of wheel weights on "my" '63 4000 I use for tractor pulls. I'd like to try to step up to the 5500-lb class...I seem to have plenty of horsepower, but no traction at all.
Anyway, if anyone knows anything about these weights, let me know...I'm all ears!
Pat
PatsPOS
05-05-2008 19:37:28
 Re: Anyone ever seen weights like this? in reply to PatsPOS, 05-03-2008 21:05:59
Dean...well, it looks like you were pretty close! I got the trusty bathroom scale out (which only seems to be accurate if I'm standing on it, not my wife! :lol: ) and came up with 163# per weight.
And showcrop...thanks for the tip. You're not the first person ever to tell me 28" (or in my case, 14.9 x 24...the tractor is a 4130 LD Industrial) wheels and tires aren't the best for pulling duty. But then I watch those antique tractor pulls on RFD-TV and I see older Fords hiking up the front wheels...I dunno. I don't think I'd ever get 38s on the back without it looking goofy. OTOH, if I can find a brake control valve for "my" 6000 this year, I'd MUCH rather try pulling with that! :twisted:
Pat
showcrop
05-04-2008 18:28:35
Hi Pat, rather than going up to 5500 with that 4000 I would suggest bigger tires. I used 16.9 28s for one season on my 960 then I went to 15.5x38s now I usually come out about even on power and traction in the 3500 and 4000 classes good luck
awhtx
05-04-2008 14:52:33
 Are these the weights Walt lists on his website? in reply to Dean, 05-04-2008 07:47:06
Walt has some axle weights listed at 304 lbs for the pair. Is this what he's selling?
8N'r--WI
05-04-2008 03:56:53
Pat---I thought these were the same, but I believe are "close".
third party image
third party image
They mount on top of the bottom fender mounting bracket behind the wheels.
These were taken off a one owner Ferguson TO-20 and are for sale (not mine) for $750.
These weights and yours are the only ones that I have ever seen.
Tim
