Tacho drive, where to buy? (Injection pump model)
Anders
05-05-2008 02:29:13
My Tacho drive unit seams broken, where I can I buy a new unit? The tacho drive sits on the end of the injection pump (Inline Minimec / Sims)
All I can find is drive units of the alternator or oilpump. Will any of these fit?
RodInNS
05-05-2008 09:29:50
 Re: Tacho drive, where to buy? (Injection pump model) in reply to Anders, 05-05-2008 02:29:13
Have your NH dealer try this number: 72NY17375B
Messicks NH lists it in their parts catologue as still available...
Rod
Anders
05-05-2008 13:19:42
 Re: Tacho drive, where to buy? (Injection pump model) in reply to RodInNS, 05-05-2008 09:29:50
RodInNS said: (quoted from post at 09:29:50 05/05/08) Have your NH dealer try this number: 72NY17375B
Rod
Thanks Rod! Will have my local dealer check it out. Otherwise I will install a electrical tacho of the generator, as I have replaced it with a 90A bosch generator with a W terminal.
RodInNS
05-05-2008 13:42:43
 Re: Tacho drive, where to buy? (Injection pump model) in reply to Anders, 05-05-2008 13:19:42
That is the number for the 7000. That's assuming that you have a 7000's pump that's ready to accept the drive. If you don't there may be more to it, so check into it carefully. I don't think it would be too hard to fit, but do some research on it...
Rod
Brian Allen
05-05-2008 07:24:56
Did you try calling/contacting this site. If it is not listed they may still be able to find it for you.
Be tractor safe.
Brian
