Order Ford 3000 Parts Online
1974 Ford 3000 weight?
604
05-05-2008 16:28:46
Any one happen to know what a 1974 gas Ford 3000 weighs? Only place I found it said a late 2000 weighs 100lbs more. That just can't be right.
RodInNS
05-05-2008 19:25:19
 Re: 1974 Ford 3000 weight? in reply to 604, 05-05-2008 16:28:46
The 2000 and 3000 are pretty much the same tractor on a casting basis. The weight on tractordata might reflect data taken from nebraska tests, and the weight given there will be 'AS TESTED', not it's nominal dry weight... so a 2000 could well have been tested as heavier than a given 3000 depending on options and ballast.
For what it's worth, the 3700 # figure sounds about correct without going to a book to check...
Rod
Vacherie
05-05-2008 18:39:50
 Re: 1974 Ford 3000 weight? in reply to Wayne Scott, 05-05-2008 16:46:20
Not all data on Tractordata is correct. I have seen several errors.
604
05-05-2008 16:49:41
Yea thats were I looked. But they also say the smaller 2000 is 3770 lbs. Just do not see how a smaller thractor is more. One can't be right. Thanks!
soundguy
05-06-2008 06:49:01
 Re: 1974 Ford 3000 weight? in reply to 604, 05-05-2008 16:49:41
As rod points out.. a 2000 and 3000 are virtually the same tractor when you get down to nuts and bolts. One is detuned.. and lower hp.. not specifically 'smaller'.
soundguy
