Order Ford 3000 Parts Online
3000 2 stage clutch (Shin Breaker)
CapnDean
01-14-2002 07:41:42
So I love the 2 stage clutch. The clutch works great. The problem is that the dang pedal is sooooo high. I realize that if I saw it off and weld the pedal back on at a reasonable height, then I won't be able to disengage the PTO properly.
Has anyone ever adjusted one of these to be user friendly? Or should I just whack my left leg off below the knee?
CapnDean
RWK in WI
01-14-2002 17:56:52
 Re: 3000 2 stage clutch (Shin Breaker) in reply to CapnDean, 01-14-2002 07:41:42
I know what you mean - with my long legs the clutch gave me fits. Then i raised the seat by putting a 3 X 4 piece of square steel tube between the seat bracket and the origional mount and moved the seat back a little and the difference was great. You might want to try it.
Ed in Fl
01-14-2002 16:28:03
I had my clutch rebuilt on my 74 2000 and then an 'old timer' came by to unload some hay. His foot never touched the pedal. He pushed on the arm that the pedal is attached to.
paul
01-14-2002 12:07:31
You can adjust some of this out of it, but it probably means your clutches are about wore out.
--->Paul
Scott
01-14-2002 09:57:29
The pressure plate need adjusted and give the pto a little extra from what the book says.
Chad
08-20-2002 21:33:06
 Re: Re: 3000 2 stage clutch (Shin Breaker) in reply to Scott, 01-14-2002 09:57:29
How do you adjust the pressure plate? The pedal height is really annoying and also my pto won't disengage most of the time when the clutch is down..?? Mine is a 75' 4000..
