Order Ford 600 Parts Online
3600 3 point stabilizer bar problems
Carl Dawson
01-14-2002 08:58:45
I have a 3600 that we use for shredding, discing, fertilizing. The stabilizer bars are very hard to re-attach when I switch implements: you have to push the implement way to one side while another person put the bar on. I see no adjustment mechanism. When I disc without stabilizers, limiting chains don't stop linkage from rubbing rear tires on turns.
Question: Is stabilizer problem normal, or have I bent/broken something? Can I just shorten limiting chains by taking a link or two out and discing w/o stabilizer.
Bill Oakes
01-15-2002 05:11:40
 Re: 3600 3 point stabilizer bar problems in reply to Carl Dawson, 01-14-2002 08:58:45
Carl,
There is one way to fix this problem - get adjustable length stabilizer bars; I did - end of problem; I love them. I found them at a number of different on-line supply houses. I can look up the supplier I used if you are interested.
TomB
01-15-2002 03:48:54
Mine only fit on a specific side. If I try to put the wrong one on it's an absolute bear but only requires a minor kick when on the proper side. Also makes a difference what way the angle faces (up or down and forward or aft end) Sounds strange but it works
RWK in WI
01-14-2002 17:51:38
There are adjustable length stabizer bars. I have some and use one when I have a piece of equipment that is difficult to hook up. They look like a giant turnbuckle or top link. My source was a person on the board in Colorado but I can't remember his name much less his email. Maybe someone else can help.
Scott
01-14-2002 09:55:04
The chain links get worn and need replaced with the correct length new ones. Do not take links out because when you raise the 3 point the chains will be too tight and strain your pump. All major brand equipment should have the same width 3 point dimensions, I know some supply store equipment has a narrower width. Do your stabilizer bars have a bend in them near one end so they clear the rear axle housing?
Jhill
01-14-2002 09:45:23
Stabilizer bars are supposed to be tight to keep the implement straight but it sounds like your limiter chains are way too long. Take out a link or 2 to keep disc out of tires.
