NCA 836B O Ring
adlerstrom
05-08-2008 11:52:55
When the lift cover repair kit arrives, how do you tell this O ring from the others that are appox. the same size. I think I might have used the wrong one on the unloading valve. Hydraulics will move up and down, but won't lift much anything. I've checked through the fill hole and can't see any fluid squirting from the cylinder. The manual doesn't comment on the special O ring for the unloading valve. I've had the lift cover off three times now and still have no lift power. TIA
Sam
Larry NCKS
05-09-2008 20:03:34
 Re: NCA 836B O Ring in reply to RodInNS, 05-08-2008 11:52:55
I don't know about availability other than NH. Guess that's something you'll have to check out. I was looking at the NH parts website in making those comments.
adlerstrom
05-09-2008 18:14:06
 Re: NCA 836B O Ring in reply to soundguy, 05-08-2008 11:52:55
Larry NCKS said: (quoted from post at 19:51:04 05/09/08)
I don't see this o-ring as part of the cover kit. Are you saying it is? As I view the parts list, you should have to purchase this o-ring seperately.
Maybe it isn't part of the kit...lol...if not, is it available hete at YT?
Sam
Larry NCKS
05-09-2008 17:51:04
 Re: NCA 836B O Ring in reply to steven cash, 05-08-2008 11:52:55
adlerstrom
05-09-2008 10:48:15
 Re: NCA 836B O Ring in reply to Brian in MA, 05-08-2008 11:52:55
Larry NCKS said: (quoted from post at 02:16:14 05/09/08)
You might get some response to this if we knew what tractor you're working on.
My apologies :D 53 Jubilee TIA
Sam
Larry NCKS
05-09-2008 00:16:14
