Order Ford 2000 Parts Online
2000round baler
Mark T
01-14-2002 14:41:41
Will a 1970 2000 3 cyl. gas run a Vemeer 605c round baler?Would be flat ground and grass hay.Thanks Mark
Bob Semrau
01-15-2002 08:06:12
 Re: 2000round baler in reply to Mark T, 01-14-2002 14:41:41
Does your 2000 even have the hydraulic remote the 605 will need ? I've run a 605 with an Oliver 1600 and I think that the 2000 would be way too small.
Somewhere on the web I found a university report on how much power it took to run a JD 510 round baler (about the same size as a 605). The peak power they measured was 27 hp - your 2000 wouldn't have enough hp left to pull it!
Mark T
01-15-2002 08:27:31
 Re: Re: 2000round baler in reply to Bob Semrau, 01-15-2002 08:06:12
It has a single remote.I use it to run a 6'Vicon disc mower with hyd lift.I didn't think it would pull the 605,I was just curious because I could use the 605 for nothing.Thanks Mark T
Andy
01-14-2002 17:44:32
Probably not, I don't know what size roller this is but I roll a 4x5 roll of hay with a 43 horse IH and it is all it wants on a hot day.
