WAIT JUST A SECOND...
Bob
05-11-2008 10:33:36
WAIT JUST A SECOND before replacing the starter solenoid for ignition problems!
From the factory, there's NO "starting bypass" on the starter solenoid on an NAA. The OEM coil is 6-Volt, and NO external resistor is used, so there is nothing for the solenoid to bypass, even if it HAD the extra "start bypass" terminal!
Third Party Image
36 coupe
05-11-2008 16:38:39
 Re: WAIT JUST A SECOND... in reply to Bob, 05-11-2008 10:33:36
That diagram needs help.Lights shouldnt be fed power thru the ignition switch.Also it looks like the coils hv output is connected to the 6v line.
Bob
05-12-2008 09:02:15
 Re: WAIT JUST A SECOND... in reply to 36 coupe, 05-11-2008 16:38:39
I AGREE on those points! HOWEVER, the part in question here is the solenoid, which IS shown correctly.
